mr_K Posted June 6, 2016 Share Posted June 6, 2016 Im doing a k20 swap into a starlet ep91.The angle of the engine is abit too forward, And the angle of the driveshafts not inline.Does the driveshaft angle need to be dead centre with the hubs, or will abit of angle be okay?Thanks Quote Link to post Share on other sites
morgey Posted June 6, 2016 Share Posted June 6, 2016 Small angle would be ok but the closer to inline the better. Quote Link to post Share on other sites
mr_K Posted June 7, 2016 Author Share Posted June 7, 2016 Okay mate thanks for that,The angle is not that bad, its just not inline thats what i was worried about causing the wheel to lock on full turns. Quote Link to post Share on other sites
Stu Posted June 7, 2016 Share Posted June 7, 2016 Shaft angle can play a part in how the torque is applied (especially with an open diff) and effect torque steer. Some angle is fine, as long as you have roughly the same on both. I don't know much about the K series engines but if they have a bearing hanger on the back of the engine then I'd try to use it as it will even out your shaft lengths which also helps with even torque distribution. Quote Link to post Share on other sites
Glanza Mac Posted June 7, 2016 Share Posted June 7, 2016 Very interested in this, any pictures of your build so far?Rob. Quote Link to post Share on other sites
gorganl2000 Posted June 7, 2016 Share Posted June 7, 2016 i believe a local track ep82 car had in a k20 swap...but have not seen it in ages or know anything about how they did iti do know is that it was reasonably fast and did some decent drag times...had some wide fender flares at the front https://www.youtube.com/watch?v=Wtx6NktySOQ i think that was it...but not sure which engine was in it at the time of the vid as i heard it originally had in a 4age 16 or 20 valve conversion in its earlier days Quote Link to post Share on other sites
mr_K Posted June 7, 2016 Author Share Posted June 7, 2016 Shaft angle can play a part in how the torque is applied (especially with an open diff) and effect torque steer. Some angle is fine, as long as you have roughly the same on both. I don't know much about the K series engines but if they have a bearing hanger on the back of the engine then I'd try to use it as it will even out your shaft lengths which also helps with even torque distribution. The k20 uses equal length driveshaft design, it has a half shaft that mounts on the engine,Looking straight at the hubs the shafts a looking slightly to the left on the inner.The angle is not too bad but i like to have everything lined up and straight, its just touching the firewall. Quote Link to post Share on other sites
morgey Posted June 7, 2016 Share Posted June 7, 2016 No possibility of cutting into the firewall? They do it with the tunnels on rwd cars to fit bigger boxes or on ae86's to fit engines with dizzys at the back of the head. Quote Link to post Share on other sites
roachburger Posted September 28, 2016 Share Posted September 28, 2016 Some angle is ok. If it's not much it may square them up as the engine moves on its mounts. As long as the inner CV joint on the shaft is in line with the inner pivot of the tie rod on the steering rack and the cv joint isn't at the daftest angle ever or at the end of it's pivoting travel it should be alrightVtec minis have a remarkably steep angle on thier driveshafts and they hold up Quote Link to post Share on other sites
