mike_flan#23 Posted July 30, 2016 Share Posted July 30, 2016 Just fitted corolla inlet on starlet really bad misfire burning oil slightly and really bad wine any advice would be much appreciated Quote Link to post Share on other sites
Pikey009 Posted July 30, 2016 Share Posted July 30, 2016 Not sure on the whine but have you checked the vac lines in regards to the missfire? When was the last time you had plugs done?- as the slight increase in air flow might have highlighted an issue.Also the mani might be fowling on something. Is the earth connected properly on the inlet aswell? Quote Link to post Share on other sites
Starlet__SR Posted July 30, 2016 Share Posted July 30, 2016 Cant the coolant and breather pipes be mixed up on the throttle body too? Quote Link to post Share on other sites
morgey Posted July 30, 2016 Share Posted July 30, 2016 Coolant lines and earth wires on inlet are common ones. Fitting the inlet shouldnt make any difference to oil burning. Could it be coolant you're smelling/seeing? Quote Link to post Share on other sites
