redliner Posted April 2, 2017 Share Posted April 2, 2017 (edited) So went to bleed the brakes but the bleed valves sheared off on the 2 back calliper's when or if i get them out can I buy new 1s from Toyota to screw back in?? Much help needed,, Thanks ger Edited April 2, 2017 by redliner Quote Link to post Share on other sites
adzy Posted April 2, 2017 Share Posted April 2, 2017 Yes I recently priced them in Toyota, were over £5 each tho. In the end I got a pair in motor factors for £1.50 Quote Link to post Share on other sites
redliner Posted April 2, 2017 Author Share Posted April 2, 2017 Aw cool that's the job, was worryed couldn't get them, just get them out now, is welding a bolt to it the best bet getting them out?? Quote Link to post Share on other sites
Starlet__SR Posted April 2, 2017 Share Posted April 2, 2017 Aw cool that's the job, was worryed couldn't get them, just get them out now, is welding a bolt to it the best bet getting them out?? Drill it out, then tap a screw extractor or at worst a torx bit inside the hole, it should wind out. Quote Link to post Share on other sites
redliner Posted April 2, 2017 Author Share Posted April 2, 2017 Right might try that, sound for the help👍 Quote Link to post Share on other sites
Starlet__SR Posted April 2, 2017 Share Posted April 2, 2017 All you need to do is enlarge the hole so you can get a decent torx bit in Quote Link to post Share on other sites
redliner Posted April 2, 2017 Author Share Posted April 2, 2017 All you need to do is enlarge the hole so you can get a decent torx bit in sounds simple enough then, did you do it this way? Quote Link to post Share on other sites
Starlet__SR Posted April 2, 2017 Share Posted April 2, 2017 sounds simple enough then, did you do it this way? It's a trick i've used for many years lol. Quote Link to post Share on other sites
redliner Posted April 2, 2017 Author Share Posted April 2, 2017 Good tryed and tested so 👍 Quote Link to post Share on other sites
redliner Posted April 5, 2017 Author Share Posted April 5, 2017 Yes I recently priced them in Toyota, were over £5 each tho. In the end I got a pair in motor factors for £1.50Rang at least 4 motor factors and none of them do the bleed valves didn't bother trying the rest, so hope toyota do them, at a prise no doubth, Quote Link to post Share on other sites
Ollieh17 Posted April 5, 2017 Share Posted April 5, 2017 I bet they do them but not listed under the reg. Try asking for them for a n/a starlet or measure them and compare them to other cars. Theres no way that bleed nipples are different to so many other cars Quote Link to post Share on other sites
adzy Posted April 5, 2017 Share Posted April 5, 2017 Toyota have them, and at a price lolI just took mine into the motorfactors and they got me one the same. Quote Link to post Share on other sites
redliner Posted April 5, 2017 Author Share Posted April 5, 2017 Ah just asked them do they do bleed valves for brake calliper's an they all said no, Rang toyota an they can get them for 9euro for the 2 of them, so will just get them there Quote Link to post Share on other sites
