westie Posted April 20, 2017 Share Posted April 20, 2017 Quick question: do I need any kind of sealant in addition to a genuine Toyota gasket or just fit it dry?Cheers. Quote Link to post Share on other sites
Fozzie Posted April 20, 2017 Share Posted April 20, 2017 I just fitted mine dry, but some people recommend putting a small blob of sealant on all the corners and around where the cams and dizzy go. Quote Link to post Share on other sites
davehart Posted April 20, 2017 Share Posted April 20, 2017 (edited) No real need for any sealant. You might use a tiny drop just so the gasket stays in place when you turn it over to put it on. I used none on mine, just pushed it into place firmley. Edited April 20, 2017 by davehart Quote Link to post Share on other sites
westie Posted April 20, 2017 Author Share Posted April 20, 2017 Awesome, cheers dudes. Quote Link to post Share on other sites
Fozzie Posted April 20, 2017 Share Posted April 20, 2017 I forgot to mention, make sure that the top of the head is completely clean where the gasket will contact it and also put a good bead of clean oil around the gasket before you pop the rocker cover back on Quote Link to post Share on other sites
westie Posted April 21, 2017 Author Share Posted April 21, 2017 Did it this afternoon, seemed to go alright. Hopefully it'll not piss oil all over the place now. Quote Link to post Share on other sites
Starlet__SR Posted April 21, 2017 Share Posted April 21, 2017 I always use silicon grease when fitting new seals. Quote Link to post Share on other sites
