Broony Posted April 29, 2017 Share Posted April 29, 2017 Alrite lads / lasses,Fitting myblive sports front bumper soon. So what im after is some pictures of them fitted and ideas for extra mounting points. The worry is running fibre glass wings the front bumper might pit too much stress on them. Any suggestions?..... Quote Link to post Share on other sites
jellybaby Posted April 30, 2017 Share Posted April 30, 2017 IJust used the oem points to fit it and new clips for the top Quote Link to post Share on other sites
Broony Posted April 30, 2017 Author Share Posted April 30, 2017 IJust used the oem points to fit it and new clips for the topDid you use the oem points near the fog lights? Quote Link to post Share on other sites
jellybaby Posted April 30, 2017 Share Posted April 30, 2017 No as there no holes drilled in them all I use it the wing ones the ones on the bottom cross member and the plastic clips ones Quote Link to post Share on other sites
Idrees Posted April 30, 2017 Share Posted April 30, 2017 I have no pictures showing the mounting points but mine was just screwed in to the wings and had 2 bolts in the slam panel (where there's usually 4 clips holding the grill in place) Quote Link to post Share on other sites
Broony Posted May 1, 2017 Author Share Posted May 1, 2017 Cheers for the info guys.I takenit you made brackets for the cross member? Just concerned about the weight on the wings Quote Link to post Share on other sites
Idrees Posted May 1, 2017 Share Posted May 1, 2017 The original bumper has holes that line up with the holes on the slam panel. Our bumpers have these holes marked so you'll just need to drill them out. There are tabs that rest on the bumper bracket just under the headlight so all the weight is not on the wings. Quote Link to post Share on other sites
