turbominicooper Posted November 3, 2017 Share Posted November 3, 2017 Which combo? 5efhe rod and gudgeon pin with 4efte piston. Or 5efhe rod with 4efte piston and gudgeon pin? Quote Link to post Share on other sites
maddox710 Posted November 3, 2017 Share Posted November 3, 2017 The 5efhe pistons have a crown so will increase compression and 4efte gudgeon pins are thicker and stronger if i remember correctly Quote Link to post Share on other sites
turbominicooper Posted November 3, 2017 Author Share Posted November 3, 2017 So use the 5efhe rods with the 4efte piston and pins? Quote Link to post Share on other sites
maddox710 Posted November 3, 2017 Share Posted November 3, 2017 What setup you doing again dude, because if you use the 4e pistons they will lower the comp on a stockish setup and make the car feel abit more lazy. We'e ii yyu uused the 5e pistons you'l ppck up a good bit of compression making the car more responsive Quote Link to post Share on other sites
turbominicooper Posted November 3, 2017 Author Share Posted November 3, 2017 Just making my 5efhte into a 5efte by swapping the 4efte pistons into it. Quote Link to post Share on other sites
gorganl2000 Posted November 3, 2017 Share Posted November 3, 2017 5 hours ago, turbominicooper said: Which combo? 5efhe rod and gudgeon pin with 4efte piston. Or 5efhe rod with 4efte piston and gudgeon pin? i dont know if it makes a difference as i have never measured the pins to see they are indeed different, but we use the 5efhe rods with 4efte pistons and 4efte pins PS---on the other side of the coin, if i were putting 5efhe pistons on 4efte rods, i'd use 4efte rods with 5efhe pistons and 5efhe pins Quote Link to post Share on other sites
5e colin Posted November 3, 2017 Share Posted November 3, 2017 dont matter what pins you use really they wont snap but rule of thumbs is use the pins from the piston it comes from Quote Link to post Share on other sites
Sudden Posted November 3, 2017 Share Posted November 3, 2017 *reinforcing what Colin said* when you buy oem pistons they come with a pin, so always keep the pin paired with the piston. Quote Link to post Share on other sites
gorganl2000 Posted November 6, 2017 Share Posted November 6, 2017 i'm agreeing with 5e Colin and Sudden...keep the package together Quote Link to post Share on other sites
