aaddzz123 Posted June 21, 2018 Share Posted June 21, 2018 Does anyone else experience any fuel starvation when cornering a little hard? If my GT has 1/4 tank of fuel or less, it doesn't like to be thrown about. I went into a roundabout earlier today and had a little bit of lift off oversteer and lost all power, AFRs read off the scale lean so I know it's starvation. I just didn't expect it to starve at 1/4 tank lol. Does anyone else have this issue? Wondering if it could be due to something else or if I should consider fabricating a swirl pot. Quote Link to post Share on other sites
akyakapotter Posted June 21, 2018 Share Posted June 21, 2018 Can't say Ive ever had that issue with the glanza mabe the tank insides are different. No harm in whipping up a swirl pot though. Cheers nick. Quote Link to post Share on other sites
aaddzz123 Posted June 22, 2018 Author Share Posted June 22, 2018 Strange. I don't want to make a pot if it's just masking an issue that should be fixed. Guess I can start by taking the pump out and seeing if it sits right or whatever. Quote Link to post Share on other sites
SKINY Posted June 22, 2018 Share Posted June 22, 2018 Mine does it when nearly empty cornering hard, also Phil had bother with it in his last GT going through the chicane on the track too Quote Link to post Share on other sites
TrisK Posted June 23, 2018 Share Posted June 23, 2018 Have you got the little baggy on the end of the fuel pump? Might be worth checking it have fallen off Quote Link to post Share on other sites
morgey Posted June 23, 2018 Share Posted June 23, 2018 Have you got the little tub/baffle that sits around the fuel pump in the tank to stop the fuel running to the extremeties of the tank Quote Link to post Share on other sites
