DIY TD04 Water lines
Got my td04 water lines locally for £50 all in. If you source all the parts yourself it will probably be a bit cheaper. If anyone is making their own you will need the following...
2x m12x1.25 to an6 adaptors
2x 45 degree an6 fittings.
An6 braided hose (length varies on different setups)
2x an6 hose end finishers.
The an6 hose diameter is a touch smaller than the water pipes on the thermostat housing, dip the hose end in hot water for a few mins and they slide on without much force.
Edited by H_D
  • 1 year later...
4 hours ago, bailiff666 said:
Hi H_D
Can you let me know what I need to fabricate oil line and what’s your solution for oil return line
Also what’s the lengths of all lines? My turbo is in standard location
Send me a pic of your set up il have a look for you
If its for a ct9 that sits in the stock position just use the original oil and water lines. My guide is for a TD04 🤦‍♂️
Edited by H_D
If its using a ct9 core the fittings are different. If its a td04 core then u need all the bits i mentioned in the original post. Will the oil feed be positioned facing straight up
Edited by H_D
