Converting too manual so need the following
  • Gearbox (Manual)
  • Clutch (pressure plate and clutch disc)
  • Flywheel
  • Flywheel bolts (shorter than the auto ones)
  • Clutch Master Cylinder (the bit with the resivoir on it)
  • Clutch Slave Cylinder (the bit that bolts onto the gearbox)
  • Clutch Lines (both metal line and rubber line)
  • Clutch Pedal Assembly
  • Brake Pedal Assembly
  • Shifter Assembly
  • Shifter cables
  • Both mounts
Gearbox needs too be in good condition with no crunching ect! Thanks
59 minutes ago, gwtaylor said:
I'm in NE and breaking a manual EP82 and have everything you need bud
Already talking too you on Facebook mate, just waiting for someone too let me know if all parts fit
