Will Scott Posted July 4, 2019 Share Posted July 4, 2019 Been having problems with getting boost at low rpm, was wondering if there are any common issues with these that I could start to look at. No engine management light on cars pretty much standard. Thanks Quote Link to post Share on other sites
gibby1980 Posted July 8, 2019 Share Posted July 8, 2019 On 7/4/2019 at 4:13 PM, Will Scott said: Been having problems with getting boost at low rpm, was wondering if there are any common issues with these that I could start to look at. No engine management light on cars pretty much standard. Thanks What turbo do you have on? Any vacuum leaks noticeable on the boost gauge? Quote Link to post Share on other sites
gibby1980 Posted July 8, 2019 Share Posted July 8, 2019 Just now, gibby1980 said: What turbo do you have on? Any vacuum leaks noticeable on the boost gauge? On the gauge, at idle you should be reading -20 or a bit more. Quote Link to post Share on other sites
RobSR Posted July 9, 2019 Share Posted July 9, 2019 HI there, If you list the full spec it would be helpful. You say fairly standard so i would guess its on a CT9 still? Does it have an adjustable actuator? If this is set incorrectly it can cause low down lag. Check the other basics, boost leaks, exhaust leaks etc etc. Quote Link to post Share on other sites
