Wetherby Aslin Posted June 9, 2020 Share Posted June 9, 2020 Hi folks, I've got an EP91 starlet. I lowered it on 35mm springs and this week tried to fit some new (2nd hand) enkei alloys (mostly because they had nice new toyo tyres) The rears fit 100% - no noticeable rubbing or anything (I did check the offset etc and the 195/50 r15s are supposed to be a good fit-right?) But the fronts contact the brakes! Doh! 1stly is it safe to run odd wheels (14" front and 15s on the rear) for a week or so while i get this sorted? 2ndly I'm after the cheapest and easiest possible solution... Which I guess is wheel spacers? Could anyone suggest any? (looks like I need to space them about 10mm each)? Or should I give up and stick the old MX5 wheels back on?! Any advise great appreciated! Thanks Wes Quote Link to post Share on other sites
akyakapotter Posted June 9, 2020 Share Posted June 9, 2020 10mm hubcentric spacer be job done Quote Link to post Share on other sites
Wetherby Aslin Posted June 9, 2020 Author Share Posted June 9, 2020 Thanks dude! Recon I'd need some longer studs too? Quote Link to post Share on other sites
akyakapotter Posted June 9, 2020 Share Posted June 9, 2020 Think you'll be alright with 10mm tbh Quote Link to post Share on other sites
