Sam44 Posted July 4, 2020 Share Posted July 4, 2020 Same colour. Get some specs unit. And more pictures if possible. Quote Link to post Share on other sites
momosr Posted July 10, 2020 Author Share Posted July 10, 2020 CT9 turbo Japspeed de-cat exhaust Standard glanza intercooler 1.6 corolla injectors Running standard 4efe ECU More pictures to come.... On 7/4/2020 at 6:26 PM, Sam44 said: Same colour. Get some specs unit. And more pictures if possible. Quote Link to post Share on other sites
Sam44 Posted July 11, 2020 Share Posted July 11, 2020 Great work. Message me more info please, boost pressure and fuel pressure if poss. Quote Link to post Share on other sites
Sam44 Posted June 27, 2021 Share Posted June 27, 2021 (edited) is this still going strong. ive been thinking of running the paseo (my build is in the paseo section on here) on low boost around 5psi on a standard tdo4 we have fitted the 7afe (230cc i think) pink injectors and a adjustable fuel reg getting the afr good at 2.2bar normally aspirated we have also increased the length of the map sensor pipe to slow the response of the map sensor out of boost so it does not over fuel in this area. on a standard 5efe ems. have you thorough of running the higher lift 4etfe inlet cam. what throttle body are you running. Edited June 27, 2021 by Sam44 Quote Link to post Share on other sites
Zemerz Posted July 13, 2021 Share Posted July 13, 2021 I hope youre still active or will reply to this lmao. Youre running stock 4EFE ecu, have you got a piggyback on it i assume? if so which? or what have you done for mapping? cheers Quote Link to post Share on other sites
