Hi,
Having an issue with my Starlet P7 horn. The horn works when wired to a positive and negative of the battery but when I plug it into the car nothing happens. I checked the earth, fuse,wiring and changed the switch assembly behind the steering. It didn't solve the problem. Any ideas?
The horn on steering wheels normally just work when the earthed.
make sure the earth connection is good on steering column
The horn itself has a power supply and bracket is earthed to the body of the car.
hope that helps
I thought it was the aftermarket steering wheel causing it, so changed back to the oem wheel and problem still occurred.
So I tired wiring it up separately to a 4 pin relay but the relay clicks but no horn and when I earth the horn on the body its on constant. Maybe I done it wrong. Would one of the two connections on the horn button be an earth?
