Been looking for some uprated headlight bulbs just thought i`d make a little guide on what bulbs our cars use
Headlight bulb (main + dipped beam are combined) = H4
Sidelight/number plate/repeater bulbs = 501
Front indicator = 180deg pins 382 Gt only? 120deg pins 581 glanza?
Interior roof light = 269 (festoon type) 31mm
Cluster bulb = 509T
Glanza Foglight (same for remix bumper) = H3C
Not sure on the EP82 fog light bulbs and the rear light bulb arrangment, If any are wrong/different feel free to add them in everyone
A
  • 1 month later...
  • 2 years later...
  • 6 months later...
  • 1 year later...
I've just used this guide to replace some bulbs, only to find they didn't fit.
Indicators - 382 bulbs have 180 degree fitment pins, whereas my Glanza has 120 degree pins, which is bulb type 581.
Also, the interior light bulb that goes in the roof is 31mm long, as yes, they come in different sizes which isn't mentioned either.
Cheers
Al
Edited by Arnold
Actually if you read the replies it is mentioned :p
asad have you considered HIDs?
and if you want to get white interior festoon bulbs its 31mm
very helpful topic
Handy topic to have though ill ammend the 1st post with the correct bulb
Nice editing ;)
Interior festoon 31mm bulb is type 269. Bulb 264 (mentioned above) is 42mm.
Edited by Arnold
