Josh@TunerLifestyle Posted December 6, 2012 Author Share Posted December 6, 2012 Polishing looks good mate, who did you get to do that? If you don't mind me asking.a mate of mine did it he does a fine job!UPDATE!painted my rear strut and changed the harness bolt points rather then have them bolted direct to the body!hopefully the cage will be coming out tonight to get painted up!thinking i might put the rear plastics in while its out as i dont like how noisy it is lol make it look smarter too Quote Link to post Share on other sites
Nanglebadger Posted December 6, 2012 Share Posted December 6, 2012 brace looks great.not feeling the carbon strips on top of the mani and rail, but fair play for doing something different.liking your work so far dude.Phil. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 6, 2012 Author Share Posted December 6, 2012 yeh i just thought id give it a try if it dosent look good when its all off ill just rip it off Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 7, 2012 Author Share Posted December 7, 2012 thats one cage out ready for painting!anyone guess the colour ? Quote Link to post Share on other sites
drongo boi Posted December 7, 2012 Share Posted December 7, 2012 haha will look good with the cage pink Quote Link to post Share on other sites
Liam_D Posted December 8, 2012 Share Posted December 8, 2012 Cage will look awesome Pink Why you changing the harness bolt points though? Thought the floor was the safest way of mounting them? Quote Link to post Share on other sites
micky boy Posted December 8, 2012 Share Posted December 8, 2012 Yeah i wouldnt trust them bolted to a hollow tube strut brace!Looking good Josh cage is going to look the nuts mate Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 9, 2012 Author Share Posted December 9, 2012 Hou said this on my first page of my build thread :The big issue with fixing harnesses to rear seat belt points is that in a front end crash, you risk badly damaging your spine because you, the seat and the harness can/do pivot forwards & down (think what would happen if the flimsy fibreglass seat back snapped!).MSA (Blue Book, Part K) say that the rear harness straps are prefered at an angle of +/- 10 degrees from horizontal, down to a max of 45 degrees. So your car would be unlikely to pass scrutineering if you mount to the rear seat belt points anyway, and you won't get to a nice shallow angle without a harness bar.Personally i took the decision that i'd rather be as safe as possible, and risk having a cage that needs re-certifying, than risk a front end impact that crushes my spine.A poorly fitted harness will be a lot more damaging than a standard seatbelt!Just trying to be abit safer! I may change them but not had time to look for better points Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 9, 2012 Author Share Posted December 9, 2012 UPDATE!spent an hour or two putting all the plastics back in ready to make a false floor already taken away alot of the road noise so well chuffed!i had to do abit of cutting so when i put the cage back in it all bolts into place nice and easy also while i was digging out the plastics i found these, anyone know what they are and where they come from?Also i bought this from my brother for £100 used like 3 times and has loads of fittings! cant wait for the weather to pick up so i can have some fun! Quote Link to post Share on other sites
Azz Posted December 9, 2012 Share Posted December 9, 2012 The black sections go were the rear bench should be next to were your standard front seat belts come from Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 9, 2012 Author Share Posted December 9, 2012 ahh thats okay then i dont need them Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 another update got some eyelids at a good price!question is now do i paint them black or silver? Quote Link to post Share on other sites
WallaceGlanza Posted December 10, 2012 Share Posted December 10, 2012 ahh thats okay then i dont need them I'd be putting them back in! They provide a bit of chassis stiffening connecting from the floor to b pillar.Builds coming along nicely. Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 even with a rear strut and a full cage? im not sure they will fit in when the cage is in tbh! Quote Link to post Share on other sites
cazzac2222 Posted December 10, 2012 Share Posted December 10, 2012 Im sure they add a little chassis strength, paint them pink and put them back in, tidy it up a little more aswell imo!! Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 yeh may do!anyone have any photos of how they fit? Quote Link to post Share on other sites
LukeSR Posted December 10, 2012 Share Posted December 10, 2012 Black lids Josh..! And I forgot how they go in Quote Link to post Share on other sites
WallaceGlanza Posted December 10, 2012 Share Posted December 10, 2012 As tesco says every little helps, as I said they brace against the B pillar which cages don't normally touch so they will stiffen that area.I don't have a photo of them any better than this:They fit under the carpet and also form the part which the rear bench clips into, I took mine out originally when I stripped out the back before deciding they were a bit "structural". Quote Link to post Share on other sites
Starbuck Posted December 10, 2012 Share Posted December 10, 2012 Black lids Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 ill look at putting them back in if i can right! another update today!this lunch i made way on the boot build.i first cut some card board to the rough shape and put it under the lip of the plastic then drew a line round the plastic to get the exact shape Once i had done this with both sides and got some measurements i put it down on a big plastic board ( lighter than wood) All i have to do now is cut it out and cover it in carpet and get some kind of foam base on it! Quote Link to post Share on other sites
_shaun_ Posted December 10, 2012 Share Posted December 10, 2012 looking realy tidy. those black braces fit with with the cage urs looks to be exactly the same as mine Quote Link to post Share on other sites
aaddzz123 Posted December 10, 2012 Share Posted December 10, 2012 Liking the progress josh! What kind of boot build are you going for? I keep toying with the idea of putting a sub in the back somehow so I can remove my parcel shelf and put speakers in the doors lol. Guess you could remove the "sticky up bit" that holds the spare in place, put your wood over the whole boot area and have your sub sitting in the wheel well... May have to have a go myself lol.... Nice progress! Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 Liking the progress josh! What kind of boot build are you going for? I keep toying with the idea of putting a sub in the back somehow so I can remove my parcel shelf and put speakers in the doors lol. Guess you could remove the "sticky up bit" that holds the spare in place, put your wood over the whole boot area and have your sub sitting in the wheel well... May have to have a go myself lol.... Nice progress!cheers i am unsure at this moment! i currently have just the two tiny speakers so fek all music in the car lol i may put a sub in! also wanting a nice smooth carpet in the back so may make some kind of ninja sub! We shall see Quote Link to post Share on other sites
Starbuck Posted December 10, 2012 Share Posted December 10, 2012 I'll be doing one like this as well. How you holding yours down? To stop vibrations etc Quote Link to post Share on other sites
Josh@TunerLifestyle Posted December 10, 2012 Author Share Posted December 10, 2012 ill be stopping the vibration by putting a foam layer on the bottom of it and to hold it down i will probs use Velcro heres another pic of the whole thing! the board is like 2 inches short so will need to do an end peace but this is not a problem Quote Link to post Share on other sites
