[rally] azerty's luv story
  • Replies 108
Posted Images
Nice I've space out the rears at 10mm and I use 205 wide tyres on the rears, with the arch lip removed, but it's so close to the arch made a hell of a difference to the handling. I have a second starlet here I'm playing with the idea of doing a track car.
Thanks for the reply and ideas. Great work.
  • 3 weeks later...
If I could recommend the 4efe cam configuration for short car park courses. I'm not sure which cams you are currently running, possible 4efte. It's only the 4efe inlet cam that has a reduced lift of .8mm this promotes low rpm torque and also will spool the Turbo up sooner. The exhaust cam is identical 4efe&4efte.
I read on a post you was considering a supercharger.
Edited by Sam44
Interesting.
I'm currently running a fully standard 4efte head. spooling the turbo sooner and have more torque at low RPM would definitly be a great thing.  I'll see if I can find a 4efe inlet cam. Does both cam needs to be changed ? or just the inlet one ?
From what you are saying, I understand it doesn't matter. can change both or inlet only.
Nice the later corrola inlet manifold also really affects low-end rpm torque and spool.
I'm thinking a slightly different setup for the short courses.
Tubular inlet and 4efe cam?? Could be a kick ass combo.
Easy swapin.
Edited by Sam44
