Rare JDM upgrade, aftermarket & OEM parts - update October 4
Item For Sale:
P9 Carat taillights.
Item Condition & Description:
Used but in fair condition. Complete with uncut wiring & plugs.
Paint is scratched and so are the chrome-colored rings around the lenses. Would need re-paining to make them 100% again.(but then again it would probably need that anyway to match your car)
Price:
€95,- + shipping
EP91%20Carat%20taillights%201_zpsvgkshxj
EP91%20Carat%20taillights%204_zpsrodf2hw
EP91%20Carat%20taillights%203_zpsdxjb1f8
EP91%20Carat%20taillights%202_zps8gjxkxs
Payment & Shipping Details:
Paypal or bank transfer accepted.
Parts are located in the Netherlands but I can ship worldwide with insurance, tracking and proof of delivery.
Pickup is also possible.
Item For Sale:
Cusco MFU (tunable ECU) for the 2E-E engine
Used but in good condition.
Based on the 89661-10010 ECU.
This is a earlier but more advanced version of the Mines/SARD/Blitz ECU as you can tweak it after installation.
I extracted the data from the EPROM to see if I didn't receive a blank one but there is indeed still data on it.
Comes including instructions (in Japanese) and is almost equal in setup then the MFU for the 4A-GE version.
Note this one uses 3 plugs so to wire it up for your EU 2E-E you probably have to modify some wiring as the EU Starlets came with a 2 plug ECU on the 2E-E (at least in the Netherlands they did)
Setting can be changed using the DIP and rotary switches.
A quick translation of the settings: (numbers are the DIP switch numbers)
1 Enable (off) or disable (on) Lambda input
2 Enable (on) Cusco ignition timing map (off)= standard map
3 & 4 work in combination: on-on / off-off / on-off / off-on to select 4 different programs:
N1: Normal Engine
NH: Performance cam
SN: Supercharged
TN: Turbocharged
5 Enable fuel change (on) no fuel change= (off)
6 Rich (on) lean (off)
7 & 8 work in combination and in combination with switches 5 & 6: on-on 5% / on-off 10% / off-on 20% / off-off 40%
(so 5 on 6 off 7 & 8 on would give 5% lean on the "under load" map)
9 Enables idle fueling to be set by volume (on) use in conjunction with the potentiometer screw and switch no. 1 on
10 stays off
Price:
€325,- + shipping
Item For Sale:
Armrest box grey.
Used but in good condition. Meant for the Yaris Funcargo P20 series (Yaris Verso in the EU) but the armrest box is the same as the one for the Starlet P/P9, Yaris P10, Sera and several more models. You simply need to fabricate your own bracket as this one won't fit the Starlet, hence the price.
Price:
€45,- + shipping
Item For Sale:
Blitz carbon clad instrument panel EP82 for the glove compartment.
Brand new, box only opened for the sake of taking pictures.
This panel consists of a metal bracket with a sheet of carbon on top.
The panel offers space for 3x 52mm meters, 2 turbo timers and a boost controller. (no instruments included)
Complete with manual, mounting hardware and stickers.
Fit's only the EP82 glove box.
Price:
€120,- + shipping
Item For Sale:
EP82 rear ABS sensor L+R
Used, working when taken of the car (as in no ABS warning light on).
Left over from when I did my rear disc brake conversion.
Price:
€45- + shipping.
Item For Sale:
New Toyota air filter.
Brand new. For the P7 diesel engines. (and a few other Toyota models as well) Part number: 17801-74010
Price:
€14- + shipping.
Item For Sale:
TRD Multi-ECU
Used but comes with original box and manual.
For the 2E-E / 2E-T / 4A-GE 16V engines.
TRD part number: 89661-SP051
This ECU has various mappings for each specific camshaft from TRD. settings for eacht group can be set with the DIP switches inside the ECU. Fine tuning can be done with the 4 dials from the cabin,
Price:
€525- + shipping.
Item For Sale:
Toyota Multibox..
3 drawer, 1DIN box. Drawers are of the push-to-open, push-to-close type.
The larger drawer front is hinged for easy access to whatever you are string in there.
All drawers are lined to avoid rattle of coins ect in the car. (card drawer only lined on the side)
Unit is in overall good condition, easy to install with a few small screws (not included)
Price:
€115- + shipping
Edited by Toyoloog
  • Replies 113
Some more parts:
Item For Sale:
ARC downforce meter
Great for cars with adjustable wings. No need for a wind tunnel, works by 2 pressure sensors between the boot and the car. Ideal for pre-track testing and adjusting of the amount of generated downforce.
Brand new in box & complete, only opened to take pics.
Instruction manual in Japanese...
Price:
€130,- + shipping
Parts are located in the Netherlands but I ship worldwide with insurance, tracking and proof of delivery.
Item For Sale:
4 Tein EDFC stepper motors.
Used, was sold to me as working.
Never tried it myself since I discovered these won't clear the hood on my AE92. (wanted to mount them to my KONI shock absorbers)
Unfortunately the controller got lost at some point when moving to my new house.
Price:
€90,- + shipping.
Edited by Toyoloog
