The budget Coilovers Setup polo 6n / golf ( rear end update )
  • 3 months later...
  • Replies 196
sooo finally figured it out why i had so much camber on my first set the holes arnt on a central line to the shock as they are on a starlet there is 2.5 to 3mm diference in it !!!!!! to top and bottom holes , so wont make that mistake again !!!!
if you do it like this camber will be almost like stock +-1 depending how good you measure
measured the front coils for stock camber did a bit of a miss calculation on the previous 1s :(
i then made a metal template for the holes
now using my template i dont need to dos around trying to align the holes and makes the job so much faster + i will have the template for future coils to :) :)
Edited by 5e colin
the pic above is the front coils mathew :)
al you do to them is do the holes on the bottom thats it !!! stock topmounts just bolt right on with no messing or modding
tomorow i am making brackets ( bolt on ) for the brake lines ( no welding this time )
bumpstops just cut in half thats al will take pic of that to there like 3 inches big i think my rears are bottoming out on them
