Well all I'm going to have order a new clutch for the car as the juddering is doing my head in when taking off or even moving the car
So what I'm trying to find out is what is the proper clutch plate size is it 200mm or 212mm or has anyone had this issue
I've given the motor factors the reg but car comes up as a Toyota starlet not a glanza which it is
  • 5 years later...
frankie are you talking about the gearbox drive/inputshaft clutch hole?
the ep91 4efe & e11 corrola 4efe clutch is 200mm diameter. the ep91 & ep82 4efte jdm clutch diameter is 212mm as stated above this clutch is also used on many other toyotas from around 1990 to 2005. in order to be able to run either the 200mm or 212mm you require the  compatible pressure plate and flywheel (i recommend getting the clutch as a kit). the gearbox drive/input-shaft clutch hole & spline count are the same.
Edited by Sam44
