Hi everyone anyone have any idea ?
My glanza S won't start it will turn over for a good solid 10 minutes before it will fire I've changed plugs ,leads didtributer cap and rotor arm still no go I've checked all vacuums as when it eventually fires it bogs until it's up to tempurture then it runs perfect and starts perfect just when I go out first thing in the morning this all happens any idea ?
That's adjusted even when I hold the throttle a little won't start it sounds like the temp sender is gone but I got a brand new one and fitted it reset the ecu and still no good engine management light is on since this all happened and it's coming up as code 21 which is 02 oxygen sensor but that's new too so I'm really stuck ha
