Danza V
    442
About Danza V
  • Birthday 05/18/1991
    Kings Lynn
    Walking my dog, driving the V not fixing it!!!
Danza V's Achievements
Member (4/8)
  1. Started it this morning and it didn't really run rough just like a little bump and that's it then settled after 2 secs... I think it may be weather or something. I don't get no smoke irvanythjng
  2. Hi all! My new diesel daily.. Mondeo 2010 tdci 2.0 ( I know it aibt a starbo, but you guys have helped me out tonnes before! ) basic clay when I start it in mornings from cold it idles rough but then soon after a couple of blips it clears up... Any ideas??
  3. Danza V
    Engine cooling
    I flushed and replaced the cooling system and ran it up and didn't loose no coolant. Just very odd as it took ages. My missus took it out for a drive and it went up to around half ( normal ).
  4. Danza V
    Engine cooling
    Hi all, I recently did a headgasket and cambelt change on my daily and changed the coolant. Now, it takes a while to get up to temp and when it does, it stays just above a quarter. I bled the system and it can through the bleed points aswel. Got tonnes if good heat through the heaters..
  5. Danza V
    Help
    Hi all, My radio doesn't seem to wanna play ball. It's basically switching on and off when you press the on button. It does take a few presses of the button to make it turn on but when it does, it does the above. I did by pass the 12v wire which is the one for when the car is running and it worked but I couldn't find a ignition live to use without that circuit being affected. Any ideas? It worked fine until one day it started. I checked fuses, wires and changed the unitt
  6. Oh right. Cool cool. Just I though it looked familiar, just couldn't remember
  7. Yeah but with a a in the middle
  8. Hi all, Had a weird symbol pop up on my car today, never seem it before lol.. I probs know it but forgot lol. It's a A with Anita clockwise arrow going around it on start up
  9. Danza V
    Alarm
    Hi all, My alarm ain't working on my car but the lights still flash when I open the car.. "/ where could I look to see if the buzzer/alarm itself is working I've checked fuses and that. My central locking don't work it moment due to my pump not working and requiring replacement.
  10. Also, when I took the head off abit if oil seeped down into the jackets how do I get that out? Not a lot but there's enough in there to make it a bit oily. Should I just reassemble and flush it several times?
  11. Just just you said to he honest mate.. Just if the engine spun over even if the belt was connected it turned over fibe
  12. Hi all, took a head off my in laws car after the belt snapped. The engine just spun when you turned the key. I've attached some photos to ask fir some advice.. The valves did hit the pistons. Not by much, but they hit. http://s1134.photobucket.com/user/west62/media/image-13.jpg.html more will be uploaded. <a href="http://s1134.photobucket.com/user/west62/media/image-12.jpg.html" target="_blank"><img src="http://i1134.photobucket.com/albums/m618/west62/image-12.jpg" border="0" alt=" photo image-12.jpg"/></a>
  13. Danza V
    Advice
  14. Danza V
    Advice
    Hi all, my in laws saxo recently snapped most of its teeth and died. The recovery told me that it had snapped but obviously as I said it didn't. However there is no compression on 2 & 3 but the belts still connected with plenty of teeth left and it still turns over. So, I'm thinking did it actually smash valves or what cause surely it should have locked up.
  15. So I suppose if your listening work your way in and tightening work to your way out in a spiral? So losingening, your start at the corner then other corner?... Help :/
