brucer
    3
    herefordshire
626 profile views
brucer's Achievements
  1. hi, what marks do the camshafts line up together with? there has been some tip-ex marks on the back of the cam gears but unsure if there correct as theres 2 different ones. thanks for any help, bruce
  2. brucer
    various parts
    im after the following for an ep82; radiator bottom hose thermostat flange housing (the part the stat sits in, has a 2 bolt flange) throttle position sensor de-cat or standard cat lambda sensor knock sensor (presume it has a small length of wiring to it?) power steering pump bracket, my pump doesn't line up with the adjuster? let me know what you have, cheaper the better ideally.
  3. brucer
    ep82 pistons
    hi all, im looking for a set of 4 pistons for a starlet gt turbo, must be in full working order with no damage. let me know what you have, the cheaper the better. thanks bruce
