L.I.am ep82
    14
About L.I.am ep82
  • Birthday 10/05/1988
    norwich
L.I.am ep82's Achievements
  1. I need a mines plug an play for my ep82 if anyone has one for sale????
  2. I'm Running a ct9 hybrid which is brand new with a new adjustable actuator. An seems whenever you put your foot down whilst in low rpm, as the boost increases it seems to splutter/misfire. But is fine if you nail it through the gears please help!!!
  3. How much do u want for it Hawwy?
  4. I've found the problem there is a little play in my actuator. Don't suppose u no anyone who's got an adjustable actuator for the ct9 hybrid?
  5. I've still got the standard top mount intercooler atm. I've got a zisco manifold and yes I used new gaskets.
  6. Changed the turbo to a ct9 hybrid tong and it's stopped the smoking now having boost problems. For some reason it will only boost to 5 psi. But I had to use the original actuator from my old ct9? Will this be my problem. I'm on a standard ecu but used to get about 9-10 psi from my old turbo. The hybrid is brand new but came with no actuator.
  7. Do you use the standard actuator from the original ct9. On the hybrid tong ct9?
  8. If your still looking. I recently got a very clean engine from Nippon auto spares. Give them a try bud
  9. It's fine when its initially started only after it been boosting does it smoke but not every time which is weird.
  10. My ep82 occasionally smokes rich blue smoke on idle when it's hot. help please.
  11. I've sent payment to you. When can I expect delivery?
  12. They're the clip in type.
  13. Ok well if they fit the 4efte engine then il buy them off you
  14. Are they still up for sale?
