sayer88
    43
About sayer88
  • Birthday 06/03/1988
  • MSN
    sayer88@hotmail.com
    isle of Wight
sayer88's Achievements
  1. what other car radiator caps fit standard glanza radiator? Thanks Dan
  2. what other car radiator caps fit standard glanza radiator? Thanks Dan
  3. No just a constant same level of noise and pitch
  4. Hi everyone started my glanza up this morning fine pulled away and a loud knocking noise started. Sounds really loud inside the car, so pulled over popped hood to check where it's coming from. The noise was a lot quieter from the engine area but noise sounds like it's coming from behind the back of the engine. Any help would be greatful. Dan
  5. Hi everyone I'm having an annoying issue with my 96glanza, if I put my foot flat down soon as revs hit between 4500-5000rpm the car starts stuttering and spluttering but if I put foot down 1/2-3/4 it will rev round to red line no problem at all????? But now every time the engine stutters it doesn't boost and it has now started to force the coolant out of the coolant bottle out of the over flow hole on the cap so much so it's come up and running down the out side of my passenger fender help!!!!! Any help or advise would be great thanks Dan.
  6. Hi people, I'm after a o2 sensor for my glanza. Dan
  7. Thanks mate I'll give that a try.
  8. Hi everyone, I'm having an annoying issue with my 96glanza, if I put my foot flat down soon as revs hit between 4500-5000rpm the car starts stuttering and spluttering but if I put foot down 1/2-3/4 it will rev round to red line no problem at all????? Any help or advise would be great thanks Dan.
  9. Hi everyone I'm after a his actuator for my ct9 and an updated fuel pump. I have a 96spec glanza. Thanks Dan. (07772969646)
  10. Thanks mate ordered 😃
  11. Hi everyone I'm in desperate need of front lowering springs or full front suspension for my Glanza nothing fancy and cheap as possible. Thanks Dan. 07772969646
  12. Hi everyone my rear drivers side caliper has given up the ghost and I need a replacement one asap. I have a 96spec glanza if anyone could help that would be great. Dan. 07772969646
  13. hI peeps in need of a white 040 glanza rear bumper money waiting needed asap. Thanks Dan.
