Guv
    10
    Birmingham
Guv's Achievements
  1. No offers mate, £130 posted.
  2. Here for sale is my wideband AEM air/fuel mixture gauge, it is practically new as it was only used on a car for a couple of days and then removed. The gauge still has the plastic film on it, the lambda bung and changeble faces are still in there packets. Location - Birmingham £130 posted
  3. The compression test was done whilst the engine was cold; reason being i did not want to warm the engine up in its current state for a period of time which could cause further damage. If the engine was warm i would have got higher results, either way cylinder 2 has got a problem.
  4. 85psi - 30psi - 80psi - 75psi.
  5. Price drop - £1200. Had a check, the starlet has not got an LSD.
  6. Here for sale are 8 performance related books i no longer need, they are like new. Postage available to UK mainland Location - Birmingham Payment through Paypal or cash on collection SOLD Thanks for looking!
  7. Here for sale are parts i no longer need. Postage available to UK mainland Location - Birmingham Payment through paypal or cash on collection Swirl Pot System 1.5 litre swirl pot, 300LPH fuel pump, Facet red motorsport fuel pump (with anti vibration kit), inline fuel filter, clamps, nuts and bolts, wiring, fuel pipes with connectors so they can be extended. Comes with two new fuel filters. £130 + postage DV26 single piston dump valve £30 + postage Custom high boost intercooler Core size - 530mm x 260mm x 60mm Overall size - 560mm x 410mm x 60mm £60 + postage Heavy duty battery cable and kill switch (7mm core) cable 1 - 12ft cable 2 - 2.5ft cable 3 - 2ft Comes with 8 lug terminals and 2 that are already fitted £40 + postage Tim oil pressure, oil temperature, water temperature gauges (will need senders for all) Comes with a new 3 gauge pod. £55 + postage 2 inch to 2.5 inch 45 degree silicone hose ( 13 inch in length) £10 + postage Thanks for looking!
  8. Here for sale is my 1994 toyota starlet gt turbo as spares or repair. The starlet started to run a little rough so I had a compression test done; all cylinders come up with low compression, the starlet has been parked up since i did the compression test and has not been started since to avoid any further damage. I do not have the spare time to fix the starlet, so it will be sold as it stands. The body has a few age related marks such as scratches and dings; the nearside rear quarter panel has some lacquer peel, 7/10 on bodywork. I have a folder full of old mots, receipts and several rolling road printouts. The most recent rolling results show 210bhp/190ftlbs. The interior is pretty much stock with the rear stripped out. The under body is very clean, the starlet is rust free. The clocks have been changed due to fuel gauge giving inaccurate readings; the mileage of the original clocks was 137521km when they were replaced. The starlet was run strictly on Shell V-power. - Location - Birmingham - Mot – 10/14 - Tax – 04/14 Engine/gearbox - Toyo sports turbo manifold (reinforced) - TD04L turbocharger - 200mm cone air filter - Straight through exhaust system with decat - FSE fuel pressure regulator - Alloy radiator - Manual boost controller (set at 1 bar) - Port matched inlet manifold - Oil catch tank - New bosch battery - Blitz front mount intercooler - Blitz intercooler pipes - Magnecor KV85 competition leads - 6 puck Paddle clutch - HKS fuel cut defender - Walbro 255 lph fuel pump - Powerflex gearbox mount (black series) Suspension/brakes - TRD front anti roll bar - KYB shocks - Tein springs - Grooved front brake discs Interior - 330mm OMP steering wheel with snap off boss - Impul clutch and brake pedals - Oil temperature gauge - Boost gauge - Pioneer head unit - Rear interior stripped out (included) Exterior - Toyota wind deflectors - OZ racing 15 inch alloys (paint flaking in areas) - Piaa standard to aero wipers - Aero rear bumper spats (included not fitted) - Aero sideskirts (included not fitted) £1200 A full receipt will be given as I am still waiting for the log book from DVLA. Please call me on 07850071456 for any information. Any inspection welcome.
  9. Hello, im after an EP82 instrument cluster in good working order. I also need an offside rear shock top mount. I will need them posted too.
