Ben-EP95
    11
About Ben-EP95
  • Birthday 04/03/1991
    Rhoose
1260 profile views
Ben-EP95's Achievements
  1. Hi all, Ive come across sorting the rear loom on my ep95 turbo project. What have you guys done regarding fitting the rear loom (keep standard or fit a glanza one?) also I have a updated fuel pump to fit, I take it the ep95 had two one to keep levels of the tank the same and one to the fuel system? Any help much appreciated
  2. Great, thanks i have done the same too now .
  3. Hello all again, just wondering with the loom off the engine. The glanza had two holes on the bulk head where the 95 only has one? Did you guys drill one in place or routed the wires via a different location? Thanks Ben
  4. Hard to tell if yours is actually on a tilt or just the picture. Let me know mate. Hope not!
  5. I do have pics but none that show the tilt i will get some by the weekend when i go down the unit. It looks similar if not slightly more to bucketep91's.
  6. Sorry haven't been on here for a while! Urrrm well i have used the original mounts just changed the inserts for poly bushed ones. I know the rear gear box mount was offset so i can see why that needs spacing (not a issue). But the engine and gearbox tilt downwards towards the passenger side. Although i can't see why really. I can adjust them no problem was just trying to work out why. Yeah I switched the sumps otherwise i wouldn't have got this far lol. No i have a stage 2 TD engine so worth the swap (Y). Thanks for the replies .
  7. Thanks for the reply. In the end i matched up the n/a one and cut mine to fit . Also found the rear gearbox mount different? The original is offset so need to shim mine out and for some reason my engine is sitting at a angle in the car. Although Both engine and gear box mount measure the same hmmmm. I will get pictures up just waiting to get it on the road then do a write up (Y).
  8. Hello all! I am going though the turbo conversion alright so far but when trying to connect up the gear box off my EP95 the turbo engine the back plate/dust plate seems to be getting in the way?? I noticed the n/a engine has a detachable plate, can i just cut mine to fit? Or do i have to change it over which would be a pain haha? Thanks Ben
