Yash Glanza V
    3
Yash Glanza V's Achievements
  1. Thanks all for helping Have adjust actuator to 1.0 exactly ,now everything running ok .Have install one Pro pressure regulator . will get one fuel pump for impreza with a friend will this be ok on a glanza.or which model should i used. Thanks again all of u for helping.
  2. Thanks all for replying Ok sorry for mistake it was the original actuator which i have removed and replace by hks.So this one is correctly install.Thanks Now i am going to install my fuel cut.I already have these settings in my car:-4 in 1 manifold,blitz dumpvalve ,hks actuator ,blitz turbo timer,Fcd,iridium power spark plugs,d2 racing,pro racer forged aluminum lug nut set,16" wheel,5 zingen exhaust,Back fire system ,set of Stainless Braided hoses ,Cross drilled grooved front discs ,Alloy power steering pulley ,Alloy alternator pulley ,Mintex Front pads,silicon alarm and auto iginition box etc.......will post some picture of my car tomorrow. For the turbo timer wire ,is not for the alarm i am looking,there is a wire which goes to the ecu to calculate by itself how much time the timershould be on. How will i know if fcd is good .is there any solution.Thanks
  3. Hi all I am new on this forum.very nice forum . I am having some problem i would like some help please. Have just install my hks actuator in my car.would like to know if it is correctly install.i have removed the original waste gate .It have two holes in it,the hks have one hole .so i have use a t to connect the two hose together then other one to the hks actuator.Is that correct? 2nd thing .i have already install my fcd correctly but even that at 1.1 bar engine rattles and yellow light display ont the dashboard.How to test if the fcd is good ot what could be the problem.any solution 3rd thng.have already install my blitz turbo timer it wokrs ok.but now i want to connect it to the ecu.i would like to know on which wire colour it goes on the ecu Can anyone please help me . Thanks in advance yash
