spingit1982
    4
    devon
spingit1982's Achievements
  1. im in bideford too, strange that!
  2. its bout an hour away from me yea, im in devon
  3. im looking to swapping my current car with it! is it a decent spec for what it is?
  4. not yet a glanza owner but have been offered a glanza and was told its a rubbish spec, also cause it has a transplanted engine to most likly walk away, not sure if the car is from an owner on here but here is the spec, i will follow any advice given 1.3 efi 16valve turbo Registered as a 1.3 non turbo This is a great little car and puts a smile on my face everytime I drive it Spec: . 15" fox multispoke lightweight wheels with all good tyres . 2.5" straight through exhaust system with oval backbox . Hybrid ct9 turbo . 2.5" downpipe decatted . Adjustable actuator set at 0.9 . Custom relocation Mushroom air filter . Hks dump valve . Turbo timer . Works engineering manual boost controller . Fuel pressure regulator set at 45psi to run 0.9/1.0 bar of boost . Electronic boost gauge with rev counter . Hks fuel cutt defencer . Deep dish steering wheel with boss . Lowered of springs 40mm . Dials have been converted to mph . Yellow fog lights . Black bonnet . Rear windows have been tinted . Pioneer CD player . Extended gear lever . Custom made front grill Car is running around 160/170 bhp With a front mounted intercooler and a piggyback ecu power should be 200-230 bhp with the right mapping This car really does go well Body work isn't the best and there is a small dent in passengers door , oil light is on but I've been told by my local garage it's the oil sensor as the cars oil is perfect doesn't use/burn any oil 1.3 efi 16valve turbo Registered as a 1.3 non turbo This is a great little car and puts a smile on my face everytime I drive it Spec: . 15" fox multispoke lightweight wheels with all good tyres . 2.5" straight through exhaust system with oval backbox . Hybrid ct9 turbo . 2.5" downpipe decatted . Adjustable actuator set at 0.9 . Custom relocation Mushroom air filter . Hks dump valve . Turbo timer . Works engineering manual boost controller . Fuel pressure regulator set at 45psi to run 0.9/1.0 bar of boost . Electronic boost gauge with rev counter . Hks fuel cutt defencer . Deep dish steering wheel with boss . Lowered of springs 40mm . Dials have been converted to mph . Yellow fog lights . Black bonnet . Rear windows have been tinted . Pioneer CD player . Extended gear lever . Custom made front grill Car is running around 160/170 bhp With a front mounted intercooler and a piggyback ecu power should be 200-230 bhp with the right mapping This car really does go well Body work isn't the best and there is a small dent in passengers door , oil light is on but I've been told by my local garage it's the oil sensor as the cars oil is perfect doesn't use/burn any oil
