SAitken1
    37
    Scotland
SAitken1's Achievements
  1. Can't believe it. I took my plugs out and the plug for cylinder 3 was cracked LOL! Rookie mistake, I should have checked them before doing anything! Suppose there's nothing wrong with new parts. Thanks again mate.
  2. Haha I guess you're right. I've just bought a new set of plugs so I'm going out to switch them and I'll let you know how I get on.
  3. Cheers for the reply bud! Ahh damn I don't want less boost haha AFR as in air fuel ratio?
  4. I've had a misfire for quite some time now, started off by replacing the Magnecor HT leads, sorted it for a few days. Replaced the dizzy cap and rotor arm, again, sorted it for a few days and it came back. I'm going for a new set of plugs today just to rule that out (NGK Iridium heat range 7). Some people have said it could be hitting fuel cut. I know it's not the best idea but I've got a HKS FCD. It's still running ct9, roughly 0.94bar of boost. FMIC, HKS mushroom filter, relocated to the front, stainless exhaust system decat, stainless manifold, FPR, it seems too high but the fuel pressure is at 4bar, it has been since I got the car 7 months ago and it's been fine up until a few months ago when the misfire started. I've got a reconditioned 4efte with just over 70,000 miles on it. Sometimes it boosts perfectly without misfiring and other times it misses like mad! I've described it best I could and listed all the mods I can remember to help you guys figure out what's causing it. Cheers!
  5. Haha holy fuck so it is!
  6. Still got pistons and rods mate?
  7. Thanks for the reply bud, it was the throttle body staying open a little bit, replaced that and the inlet and it's fine now. Cheers
  8. Hey guys, was out a drive there and when I downshifted I noticed the revs didn't go down below 2krpm when I dipped the clutch. I thought the pedal may have been jammed but I pulled it back with my foot and it was still doing it, so I dipped the clutch again and revved and it went straight down to about 800. Done it a few times today. Any ideas?
  9. Eat, Sleep, Boost, Repeat
  10. Thanks for the replies. My mechanic just told me it's not sparking when it's cold, it takes a few turns and eventually it starts as if nothing is wrong lol. It also sounds to me like a bad earth, I will try and jump start it tomorrow and if it goes straight away then I know it's an earth. Thanks again.
  11. How's it going guys. I just got a new engine put in, and when I try to start the car it doesn't want to, and sounds like the battery is completely dead, then all of a sudden it'll start. When it's heated up and you kill the engine and start it again it's fine. I can rule out alternator, starter motor, leads and coil pack. Cheers!
  12. Hi guys, I unfortunately blew my engine over the weekend. At my local scrapyard there is an N/A Glanza S and the engine is perfect, cheap as chips too, I was wondering if I could just take that and add all my extras, turbo, manifold, FMIC etc. Also does the block have a turbo oil feed pipe?
  13. Thanks for the reply, I'm not exactly sure, it was my mechanic the clutch got delivered too, whatever it was he said it was too small. I hope he hasn't sent it back yet lol. I will say to him, thank you!
  14. Hi guys, I am in need of a clutch ASAP as there's a local car show tomorrow, the idiots from the auto shop in my area sent the wrong one, I'm in Scotland
  15. Yeah I'm not sure what to believe haha, I guess there's only one way to find out
