srferreras
    83
About srferreras
  • Birthday 12/15/1981
    Dominicana
srferreras's Achievements
  1. Zisco intake manifold. 5e colin Zisco intake How do I get a good idle?
  2. Dear, is it possible to install the idle control valve in a custom intake manifold?
  3. Dear, is it possible to install the idle control valve in a custom intake manifold?
  4. Hi mates. I need the diagram to install it
  5. I want to make 18g. I want to know how.
  6. There are many theories, I searched results. 297whp at 1.1. I recommend changing cams for these engines designed for the economy
  7. you're right AdamB . apparently it is very difficult to make this update
  8. I mates, best choise for drag use C52 or C150? 300whp and 22x8 full slick
  9. I want to order it in ferrea.com
  10. 1.5mm more
  11. Thanks AdamB
  12. thanks phil I want to confirm because I want to order custom-made valves EXHAUST, I found this specification in a forum: INTAKE Head Diam: 29mm EXHAUST Head Diam: 25mm Stem Diam: 5.97 Length: 93.3
  13. Hi mates, I need this information 4EFTE STOCK VALVE SPEC Head Diam: Stem Diam: Length: Thanks
  14. Thanks madd 16v is best for 4efte or is the same?
  15. Hi mates I need number parts for 4AG heat studs to adapt to 4efte
