16 -
UK
Bramham89's Achievements
The engine machine shop has honed it and fitted new rings which should last about 2000 miles they said. It will have to do for now as I'm moving house in December and need to get the car moving. As long as it passes one MoT that'll keep me going for a year. I might have time at a later date to do a 4efe swap or failing that there's the odd 1e starlet breaking on ebay from time to time.
I've got the block stripped and checked my ring gaps with the old piston rings and got somewhere around 1.5 mm I took the block to a local engine shop and they said it looked like an engine that had done very high mileage. It had worn 2 grooves inside the bores top and bottom. (I thought that was normal) I need to take the pistons and rings so they can check if there is anything they can do with it, but it's not looking good. It would need a re-bore but there's not any O/S pistons/rings big enough for the bore it would require, and putting liners in is just stupidly expensive. So I've gone back to looking at a replacement engine, which is way more work than I had expected. Basically nothing from my existing set-up bolts onto the cylinder head of a 4efe. So my only option is to do a full swap with EFI. OR I could fit my 1e head to the 4efe block. I have already checked the alignment and it should bolt on without any problems as the block is almost identical with a slightly larger bore (from 70.5mm on the 1e to 74mm on the 4efe). I have absolutely no idea how the carb setup would cope with the extra CC. There may also be a chance that I could use my 1E crank to reduce the stroke and compression ratio for the smaller combustion chamber in the 1e head. That would bring it down to a 1100cc and everything else should cope well with that set-up. So fingers crossed the crank fits and I should be onto a winner. I won't need to bother changing it on the log book either as there's barely any difference. Having said all that, might be worth pricing up a rebore to 74mm to take 4efe pistons and fit new rings, I can't see any reason why that wouldn't work. That way I can rule out any further piston ring leakage too. Too many options! I'm liking the last one the best I think. Seems cheapest/safest.
I've finally got some good evidence that my piston rings are causing my issues. The first leak down test was done with the rocker cover on. I've just tested again with the cover off and found that the valves are only shut on one of the strokes where the piston is at TDC on this engine. All 4 cylinders leak through the crank case, and not through head, inlet or exhaust. I also did another compression test with some oil down the spark plug holes and the compression shot up to the 180 PSI mark. So it's not what I was hoping for but at least I know what needs to be done now. I learnt some lessons that hopefully some others can learn from too: 1. Putting oil down the spark plug holes for a compression test really is worthwhile if you suspect worn piston rings (don't know why I didn't try this before) 1a. Don't put too much oil down, only about a cap full. The first one I did spewed oil everywhere with the push on rubber type connector on the compression tester and then with the screw in adapter made 250 PSI woops! 2. If your doing a leak down test, do it with the rocker cover off and check that the vales are fully shut on the cylinder your testing, if not a full revolution on the CRANK will sort things out. 3. Blue smoke caused by burning oil really can look white if you want it to badly enough. Don't kid yourself lol. 4. 150 PSI compression is really NOT OK for these engines. I'm guessing it should be closer to 180 PSI So there you go, I've no idea how I've knacked the piston rings, could just have been from a couple of hundred miles with slightly low oil. Could have been the broken timing belt, that's when it first started, even though there was no damage to the valves or the piston tops or the bores. Anyway thank you for all your time, help and suggestions. It is much appreciated!
Definitely not a bent valve. I've put some smoke stop in to thicken the oil and it there may be a slight improvement but it's still smoking. Still lots of moisture coming from the exhaust but no loss of coolant :| The rockers are adjustable and all the valve gaps are set. I may take the head off and check the valve seals properly. Might also stick it in for the mot and just hope for the best. At least I'll find out if it's oil or steam lol.
I can't smell any gases in the coolant and there were no bubbles coming out of the coolant system. :/ To be honest it is possible that the head gasket has failed I guess, or the head cracked. When I did the leak down test the air coming from the inlet exhaust could be going through an open valve in the adjacent cylinder. Maybe. I think I'm at the point now where I might just ask the garage to diagnose it for me. Get them to do a proper leak down test and emissions test. I'm completely clueless right now as there are so many things it could be. Really reluctant to take it to the garage though, I know they're just gonna empty my bank account in labour fees.
I just started the car up again today to see how bad the smoke was, as I've noticed it less the last time it was driven out the rear view. It seems that there is barely any smoke at all when it first starts up, even with a little dab on the accelerator. There is however some sooty water dribbling out the back after a bit of a rev. Once warmed up is when it really starts to smoke, although I am convinced that it is steam. It doesn't have much of a smell to it and I think it only looked the slightest bit blue as it blew over the tarmac. Looks completely white to me on our concrete drive. What do you think could cause the smoke? Should I just re-grind the valve seats and stick it in for the MoT? Surely the emissions test will tell me if its oil burning or water/steam?
OK, so I attempted my leak down test today, although the tester was playing up so didn't read the percentage of leakage (never returned to 100% and went to way past 0% when it wasn't even connected and blowing air out the end) The leak down test was done with the engine quite cold unfortunately as I was in a rush and the tester wasn't working right anyway. I made sure each cylinder was at TDC using the crank pulley markings and checking with a cable down the spark plug hole. (1 and 4 done together then 2 and 3) Despite not having the percentage of leaking, I found where each cylinder was leaking from. The results are as follows: Cylinder 1 - Leaked quite quickly out the inlet. Cylinder 2 - Holds the pressure very well, the air whistled slightly from the small breather hole in the rocker cover. Cylinder 3 - Leaked quite quickly out the exhaust Cylinder 4 - Leaked quite quickly out the inlet Also worth noting is that the cylinder 2 spark plug had a small amount of oil/soot on it, these plugs were all new after the stem seals were changed. So I am fairly sure I've done a crap job of re-grinding the valve seats. As for the oil on spark plug 2 I have no idea. I can only assume that the smoke is related to bad sealing around the valves? Not quite sure how it would cause it though. I'll see if I can exchange the tester I had for a working one and repeat the test with a hot engine, but I can't imagine the engine temp making a massive difference to the very bad seal on the valves. I'll also check the cam timing again, although it drives too well for me to think its out of time. The thing that confuses me the most is that the inlet valves had looked to be in good condition with no pitting :/
Is it worth changing the rings without pulling the engine out to have it honed at a shop? I know the bores are silky smooth so it's not gonna help with bedding the new rings in. I'd be willing to try it if it were possible to remove the pistons and reinstall them through the sump but it seems like a bad short-cut to me.
I will check the breather hoses tonight if I get chance. Hadn't thought of that, although it did only start after the timing belt failure. Will let you know soon. 4efte would be ace but also costs the price of the car to buy one lol. I'm guessing plugging the injector holes is just a case of finding a bolt with the correct thread and cutting it down? And if I can't use the mechanical fuel pump a leccy one with a regulator? I already have a cheapo regulator. Any chance of using the old 1e carb? Just to save some pennies, I'm not fussed if it only ends up making the same bhp as the 1e as long as the reliability is good.
I managed to find a leak down tester cheap enough and I've tracked down a compressor I can borrow. I'll post up the results when it arrives, and see if I can make any sense of them. If it does turn out to be the piston rings would an engine swap be much hassle? I will try track down a 1E but I've seen some 4EFE conversions with a carb but there's no write-ups. They are more easily available and probably cheaper too. I'm looking the quickest, easiest and cheapest option, I don't have any interest in extra power etc. Cheers Phil
Hi there, sorry for the long post. I really need some help though, I'm completely stuck. I have an EP70 starlet with low mileage in great overall condition and I'm keen to keep it running. It has a 1E engine When I bought the car it drove well, good on fuel, no smoking, no misfiring. It had been stood a while so the old oil had caked the inside of the rocker cover and the head and the ignition timing was advanced too far, but once fixed it ran better. Then the timing belt snapped I put a new belt on and did a compression test, just turning it by hand. It would probably have got OK results, if I hadn't timed it up wrong (nothing was hitting though). But since I had timed it wrong I assumed the worse and took the head off to check the damage: 3 snapped rockers but everything else looked fine. No bent valves no marks on the pistons. At this point I had already bought a used replacement head, which looked in better condition than my old one as it wasn't covered in oil deposits. So I put it all back together with the head I bought with a new head gasket and used some high temp instant gasket to aid the seal on the intake and other gaskets which were all in good condition. Once it was back together it started fine and ran fairly well but there was clearly something wrong, as it stuttered a bit on idle and smoked a bit. I drove it around like that for a while (I needed it running) and realised that the smoke must have been burnt oil as my oil light flickered on after about 200 miles. First thought it was piston rings. Did a compression test and was getting 155, 160, 160, 155. I thought that was OK. There was fumes coming from the oil filler cap but (stupidly) also though this could just be leaking from the exhaust valve stem seals. So I decided to change the valve stem seals, and re-ground the valve seats while I had them out. There was some pitting around the exhaust valves but intake were fine. The old head gasket had no signs of failure either. So it all went back together again with another new head gasket and new spark plugs this time (one cracked taking it out). It started straight away seemed to be running a little smoother and had a little more power but still smoking. Quite a lot of smoke. It's mostly white but maybe with a blue tinge (not sure). I've fiddled with the carb a bit which makes absolutely no difference to the smoke, so now that's just adjusted by guesswork. Although the cam timing, ignition timing, points gap, valve clearance and spark plug gaps have all been checked and set according to Haynes and Autodata's specs. Its MoT has now run out so I booked it in to get the carb adjusted properly with an MoT and just hoped they could get it to scrape through but when I got there they couldn't test it (MoT machine broke) but said it would fail anyway on emissions. On the way back under hard acceleration when I let off the accelerator it made one pop noise and then didn't idle too well afterwards. I did another compression test just now and got 150, 155, 155, 152 psi. Started it up again afterwards and it made another single loud pop after dabbing the throttle slightly. So I'm guessing the symptoms could still point to worn piston rings but I wanted to be sure before going down that route. I obviously need to get the carb adjusted properly at some point once I get the underlying problem fixed. I can't say if the oil level is going down since the valve stem seals were changed as its not driven more than 20 miles due to no MoT. I would really appreciate any advice. I should probably get a leak down tester but its more expense to my near zero budget. Thank you in advance and thanks for reading through! Phil
