Speedvision Cam Gears are designed to increase horsepower and torque without any cam changes, and are ideal for heavily modified engines. Either with OEM or Speedvision Camshafts, adjustments can be made to tune an engine’s power band to the optimum RPM range for a particular application. These adjustable cam gears are with twelve degrees (both advance and retard) of laser engraving adjustments, you can be assured of proper and precise tuning. Made from the highest quality AL7075-T6 billet aluminum,the hard-anodized finish prevents premature wear. They allow fine adjustments to cam timing with simple hand tools so you can maximize engine performance anywhere whether you’re in the pits or in your own garage. Engraved Timing marks accurate to within 1 minute of a degree (60 minutes in a degree) Easy to read marks, laser engraved not painted or etched. Tooth profile match to OEM spec. Long term reliability of the teeth and timing belt are directly related to the shape of the tooth profile. The outer cog section of our gears is hard-anodized, to prevent wear from the timing belt. Below is a video from one of our customers. His before result with stock cams and cam gear at 12 psi was 260 hp, installation of the Speedvision cams and adjustable lightweight cam gear at the same 12 psi got them a result of 305 hp. Thats a 45 hp increase. Look at the video.
