Colin1989
    76
    Alnwick
2599 profile views
Colin1989's Achievements
  1. Sorry been away. There Osram bulbs I can't remember the model of osram tho. I'll get some photo's as soon as I can. How do I tell if its a voltage issue? Correctly adjusted at a garage but may try tweeking them up a bit more.
  2. After fitting a new bulb to my subaru forsester i realized it uses the same bulbs as my glanza but the headlights on it are soooooo much better. Why are the glanza headlights so bad? I've got new headlights good bulbs and there still not good. Anyone know why there so bad?
  3. They are second hand I've fitted the front and adjusted them all level now and hasnt done it again so hope it just wasnt tight enough and weight and see if it happens again. Cheers Colin.
  4. I fitted rear coilovers last week was going to fit the fronts on Wednesday this week but just noticed one of them has dropped alot lower its been fine the last fee days untill today. I know suspention needs to settle but why has one dropped and not the other?
  5. I'm looking for the part number for interior trim clips. Ones that hold the sill covers and rear bin panels in place. Cheers Colin.
  6. What wheel nuts are supposed to be used with the spare space saver wheel? My car came with aftermarket wheels on it and the wheen nuts are definitely not the right ones. Cheers Colin
  7. Cheers lad its had me puzzled
  8. Is there anyway to fit a removable boss to the standard wheel. Just want to make my car harder to steel but not a fan of aftermarket wheels. I understand that the airbag wouldn't work.
  9. Just got a ajustable pan hard rod came with a thick spacer washer anyone know what its for?
  10. So eventually had time to look at it, i found a slightly loose lead and plushed it back on there's a rattle when I pushed it back on think the spark plug may have worked it's way loose. Now the leads on it runs better but still need to tighten up the plug and give it another once-over when I get time.
  11. Colin1989
    Help please
    Help hit a pot hole now my cars running like crap. Push the accelerator sometimes has power sometimes just judders revs drop low and engine cut out to. And running very rich used half a tank nursing it the 30 miles home. Any ideas?
  12. Cheers for all the help whats the differents between rainsport 2 and 3's? Just googled them and both show up.
  13. I've found my glanza aquaplanes alot is this a commen problem as the cars are light or is it my wheel/tyre choice or could it be my alignment? I've got 15 x 7 rota grid wheels with toyo t1r tyres cars all standard other then that. Any help is much appreciate Thanks Colin.
  14. I've always wanted a carbon varis spoiler
  15. are japanparts.com a reputable company?
