maloo
    14
    malta
914 profile views
maloo's Achievements
  1. to tell you the truth thats what i did... but i want to leave it like that, i thought maybe something else is wrong... But thats the only solution i think :/ Thanks for your help
  2. @ 5e colin yes it is a 4efte fly wheel i checked they have the same tooth same height same width. And yes im seeing marks on the flywheel (starter side) @daniel_g i just bought al lightweight flywheel its brand new
  3. Hi i just replaced my clutch kit since it was slipping and i thought of making a light weight flywheel. I fitted everything and when i went to start the engine wasn't cranking good and i heard a noise metal to metal and the engine couldn't start I removed the gearbox and found that the starter wheel gear was stucking with the flywheel ring. (when it was going out it was stucking and remains stuck with the flywheel ring) Anyone of you might know what can be the problem?? Thanks
  4. maloo
    Helix Clucth Kit
    Anyone have a new Helix clucth kit (paddle clucth)for sale please
  5. Im not 100% sure that it from the Fcd or not, but the Fcd have be been there for a while now. Maybe the Fcd is playing too and causing the problem. I ll check the throttle first and then I ll check the Fcd Thanks for your help
  6. It stays on. If I hold slightly hold the throttle
  7. no its been a while now that its fitted
  8. Hi guys yesterday i went to start my car and i didn't hold on idle and it switched off, i went to start the engine again and its like the engine is stalling. Engine check came on and i gave three code 12: Turn Signal System 1 [NE, G1 (4E-FET) ] 31:Vacuum sensor signal system [PIM,VC,E2] 34: Fuel cut I have an HKS Fcd Someone knows whats the problem Thanks
  9. Hi guys yesterday i went to start my car and i didn't hold on idle and it switched off, i went to start the engine again and its like the engine is stalling. Engine check came on and i gave three code 12: Turn Signal System 1 [NE, G1 (4E-FET) ] 31:Vacuum sensor signal system [PIM,VC,E2] 34: Fuel cut I have an HKS Fcd Someone knows whats the problem Thanks
  10. i checked it, it not leaking from there for sure cause and i think if it was leaking from there the oil goes down to the timing belt i think its more like valve seat or something like that Thanks
  11. Ok I ll check that thanks
  12. Yes driver side I seem that it's coming from no 1 and 2 cylinder
  13. Front side and it seems coming from the first and second cylinder
  14. Hi guys i need some help maybe someone have already passed from this problem. I recently fitted a TD04 on my 4e engine and i noticed that there is an oil leak between the cylinder head block and the exhaust manifold. Some people told that i could be an oil ring broken but i think it will misfire or something if an oil ring is broken. others told me that it could be the valve seals worm. Does anyone know what the problem might be or maybe someone have already seen like this. Thanks
