nasif
    20
    Asia
nasif's Achievements
  1. I don't think so, mine has different mounting position mate. The hole is faced vertically and in the pic it is horizontally.
  2. Does any one have this rear sway bar installed on their car? I need some pictures of it. It came off an EP82, now I want to install it on a EP91. The links are missing, how can i get the links? any clue? If i can't buy the links, i will make them so I need clear pictures and some instructions. Thanks!
  3. I'll be running the stock ecu for a while before i can save up and go grab a aem fic because our tuner here doesn't feel comfortable using emb. I might get a fcd to bypass the fuel cut for now and boost it below 1bar. Another question, is a rx7 top mount intercooler sufficient for running a tf035? I've heard people running td04 with the rx7 tmic.
  4. surely mate, any idea how much can it make on a healthy engine with a stock ecu?
  5. Definitely going for the tf035!
  6. thanks everyone, appreciate the help
  7. Will try maxing the ct9 for now. I want to get the tf035hm-10t-5 off a colt ralliart, is it any less capable than forester ones?
  8. I found one off a mitsubishi colt ralliart, will it give me similar output as the forester ones?
  9. Thanks mate, I'm not aiming for more than 220 hp at this moment. Do you have any idea about tf035hm-10t-5 turbos? Looking at one for a bargain, thinking of grabbing that and make a custom manifold to suit it. What's your opinion?
  10. Speedvision hybrid ct9 or Tf035? Low on budget right now so need bang for the buck.
  11. doesn't shake when the oil temp is below 80 degree Celsius that too only while idling. I'm just looking for clues why the engine shuts off when i'm flooring the car. normal black smoke, running a decat side exit exhaust
  12. ^Thanks for the information mate, i'll surely check all the wiring. One more thing to add, after a hard run the car engine keeps on shaking a bit. Later on when the engine cools down, everything seems fine.
  13. Hi, i own a 97 glanza v. Whenever i'm crossing 80 degree celcius on the oil temp gauge and going 140+ kmph my car shuts off automatically. It's a stock engine with a recently done manual transmission swap. Is the engine dying or is it somethng else that has gone bad? Any help is much appriciated.
  14. Looking for a pair of rear sway bar link including L brackets, bushes, nuts & bolts for whiteline sway bar. I have the sway bar but don't have the links, that's why willing to purchase the extra bits only. Any leads would be much appreciated.
  15. Does it look like a td04? I don't own it, the lad is asking way too much and it's in asia so shipping to uk won't be cheap.
