tangul
    3
About tangul
  • Birthday 05/05/1989
    cyprus
tangul's Achievements
  1. i tried that but it didnt work. I will buy a sensor + cables + gauge i think..I found them but the guy is asking for 250 sterlins. I will go to see tomorrow.
  2. Hello guys. I have this question. I have a 4efte engine on a Ep81. I use it as a drag car and because of this reason i removed the original gauge..and I lost it. Now i finished the car but i dont have launch control because i dont have a signal for speed. My programmer told me that i either need an electronic speed sensor for gearbox OR i need a sensor with cable + cable + a speedometer. My questions are; what sensor do i need? is there a car brand that i can use its sensor like toyota iq or avensis or corolla something? also, do a speedometer with gauge has a signal behind it? i dont see how that thing works. Please let me know your ideas. Thanks a lot
  3. Hello guys. I am Mustafa from cyprus. I have a 1993 model Toyota Starlet. I swapped the engine to 4efte. I started this project around 6 years ago. I finished it recently. I reach 400hp on engine and 320bhp. With all the weight reduction i have done the car is pretty fast I did many changes on the car. My engine specifications are -Wiseco 8.1 Pistons -Pauter Con Rods -1.5 5efte Camshafts -ACL Bearings -ARP Struds -Athena 1.4 mm Head Gasket -Ported Polished head -Zisco Exhaust Manifold -Zisco Inlet Manifold -K20 Coils -TPS Sensor from Honda B-Series -Zisco Throttle Body -Front Mount Intercooler -Nos -EK9 Radiator -HKS Fcon VproII 3.3 Ecu -Garrett GTX3071R BallBearing Turbo -38mm Tial vband External Westgate -Handmade Exhaust System -Custom Made Engine and Dashboard Loom -4 Bar Map Sensor -10lt Summit Racing Fuel Tank -Bosch 044 Fuel Pump -Sard Regulator -Sard 1000cc Injectors -Cusco 1-way LSD -C52 Gearbox -ACT 6-pad Springless Metal Clutch I also did many changes for the body of the car. Can was re-made. exterior, interior and Engine bay is repainted. I also build a custom rollcage inside. I cut and removed the spare tyre place and straight up that place with aleminium. I also have; -17" TE37 Replica Rims with eagle F1 Tyres (for showroom) - 15" Tyres with Semi-Silic Tri-Ace Racing Master Tyres - Custo Coilovers - Bushing Kit - Wilwood Brakes - Converted rear DrumPads to Discs as well
