adamsmith89
    30
    bromsgrove
adamsmith89's Achievements
  1. What does it read up to?
  2. As above I have a japspeed exhaust looking to swop for a hks silent will put money your way or swap for something quieter
  3. Will be leads
  4. I have Adam can only get it to read 0.00 or ol
  5. Ohhhh so my car is the upper class now
  6. That's crazy I just paid £71 from racetech for an oil feed pipe
  7. I think the tps is fucked I get 0.00 ohm then if you touch the trottle a little bit you get overlevel.
  8. Will do gazza I'll put my standard one back on
  9. I have a black rear gearbox mount an the vibrations are terrible
  10. Any ideas about the fuel in the vaccum pipe for the fpr?
  11. Cheers guys well I have turned the pressure down to 30psi but I think it's still overfueling slight black smoke and smell of fuel. I'll also check the dome fuse I havent got a cd player to try. Yeah very jerky I have to ease it off
  12. 2.4 bar isnt that standard pressure?
  13. Right guys put my freshly built engine in the weekend oil pressure is good etc no major problems just a few I could use some help with driving slowly in 1st and 2nd I mainly notice it coming off throttle is very harsh. my rrfpr the clear vacuum line has fuel in it is it fucked? I have turned the fuel down to 36psi as I an running on minimal boost until its mapped. boosts to the first little bar past 0. cig lighter socket no worky where's the fuse? same with the interior light Think thats it only done 70 miles in it so far so good until I had a blow out tonight.
  14. Thanks for your help guys all sorted I had it gapped at the machine shop
  15. I have a ring file and feeler gauges I'm just not sure how to work out the sizes I need
