Littleg
    6
    Essex
Littleg's Achievements
  1. Hi people just a update in the end I decided to take the head off and the results was deffo headgasket I've had skim and a new 1.2m uprated headgasket put in and all is well had 2 very small breaks in the head gasket one on the water way and one via a oil way ...... yh software deffo won't work for this lol thanks for all advice and help
  2. Andy I'm thinking headgasket even tho its past a sniff test if it is its a very minor leak I will try that programme get pal to download it and give it a ago fuel wise I'm running 99 Ron I've not tried a oil change yet but will next week when get paid
  3. Thanks 5e Colin don't think valve steams as it dose it all the time but I will nip the manifold of and have a gander turbo seems gs no movement in or out or up n down side to side etc really scratching my head as passed a sniff test and comp test ..... I have just checked the spark plugs 3 and 4 was perfect 1 and to were a white ish colour at the tips all were dry I did notice on 1st start up there was tiny tiny one spit of fluid pip out of the mainfold which might be condensation it's a ss mainfold and I'm de cat to if makes any difference at all
  4. I'll check the plugs a little later and will report back.... and yes there is a small drip from the exhaust every 5 seconds or so
  5. I didn't think of that how can I test for that mate other than getting it on the wide band
  6. Hi all.... Bit of a odd one I have some white/blue smoke I'd say it's white but it could have a small tinge of blue coming out the exhaust It's quite thick I've tested the headgasket and that's fine I've checked the turbo and that's also fine I check the rings and pistons the have also come back fine Can't be the pvc as mine been taken out and still smokes The car it self runs a1 can't fault it at all just stumped to what could be the cause And info or recommendation would be really helpful many thanks
