Hi all, I'm really struggling to get my glanza started and looking for some expert help on what to check or possible causes. First off, it's a 4EFE engine with all the turbo 4EFTE parts on it and running a FTE ECU. the car just wouldn't start 1 day 2 years ago so I put it into storage and focused on my other build and that's where it lay for 2 years. I'm now in a position to get it back on the road but I just can't get it started. I've got plenty fuel pressure in the fuel rail, I fitted new HT leads and I'm getting a spark, but I'm not getting any voltage to the injectors when turning over which I presume isn't normal? I've checked all fuses and relays in the engine bay and the fuse box under the steering wheel and all are ok and present. I've drained the tank and put fresh v power in it and a fresh battery but still no luck. Is there an efi box that I should be checking or something similar? I'd really appreciate any help whatsoever as I'm at my witts end!
