elektro_freakz
    4
    Holland
elektro_freakz's Achievements
  1. Hi guys, i'm looking for an aftermarket 4efte exhaust manifold. No toyosport autobahn88 or other ebay crap pls. Need shipping to netherlands
  2. do you sell it?
  3. Hello, With my 4efte engine i have some troubles. Since i have swapped my 2e-e for the 4efte i have got a diagnostic code 14 in the ECU. resetting the ECU won't solve the problem. I replaced the complete ignition system, ignition leads, spark plugs, ignition coil, ignition controller and distributor cap plus the rotor thingy. Mostly when i start my car there are no problems. But when i put the car to a stop, and wait for about 5 to 10 minutes and want to restart the engine i can't get it running on the first try. The engine has to "rotate" about 5 to 6 times before it goes by itself and starts. I found the diagnostic information on the forum and it says this: The ignition is almost new so i don't think that's a problem. What can cause this problem?
  4. Hello! I am Fabian from the Netherlands. I own an ep80 with 4e-fte conversion. Still running on factory boost because it's my daily car, and don't want to brake it lol. Hope to get some info here about the 4e-fte engine. Have some problems but will ask them in a separate topic. little spec list: Custom FMIC Honda civic small radiator EP91 brake calipers Paseo brake disks (will get newer slotted disks) front anti lift bar front anti roll bar dropped 40mm (red spring) KONI shocks front and rear Custom 2.5 inch catback exhaust removed katalyst Bigger ignition leads (Complete new ignition) and so on...
