Robep82
    22
    Stalbans
Robep82's Achievements
  1. Hi mate yes the engine light goes out its setup with a sandwich plate but im also get smoke coming out of the catch tank
  2. Well ive just done a oil change and filter and its still flashing and reading 0 on the car dash theres no engine light or anything. So surely if there was a problem there would be something on the dash ? Aparrently theyre trisco gauges
  3. My oil pressure gauge stepper motor is flashing and no pressure atall what could this be
  4. Finaly got the car started but its smoking and the heat temp and oil pressure gauges are flashing at me oh dear lol
  5. Yeah the inlet cam as 2small dots and the exhaust cam has 1big dot and 1 small dotif aligned if with the big dot as when I put the pulley on with 4e slot it works out to the dot with the head if that makes sense
  6. I was told on here if the timing is out then the cams could be opening before the stroke making the compression weak but I did timing yesterday and it's 100% unless I'm getting the marks wrong on the cams which I don't think I have as the cam pulley wouldn't line up if so Just having low compression on all 4 cylinders
  7. OK mate I'll have a look tonight but why would it not start if it is connected ? I know the gauge on the dash always sTayside at hot
  8. Is there a guide for this ?
  9. Would ignitions timing need to be done if the head gaskets been done
  10. Need someone with experience and knowledge to have a look at Mt gt turbo I'm slowly giving up on it imay in St albans
  11. Having issues to get the gt starting it's just had a head gasket done so does it need to be in diagnostic mode while setting crank timing ? Or only ignition timing ?
  12. That's the thing I'm not sure what's the problems apart from its turning over and not starting it had a head gasket done and since then I've had timing problems which have hopefully now been sorted compression problem which was hopefully down to the timing being off
  13. Hey guys just looking for anyone with experience on an 4efte ep82 as whatever I do I can't get the damnn car sorted.
