Shan Singh
    38
    Guyana
1559 profile views
Shan Singh's Achievements
  1. Hey guys i bought a new engine and loom after mine was sold out, i then realized that the blue was shattered and just the wires were left. Can someone help me please with this. There is 7 on that plug but i dont know which pin to put it in. Both sides are color coded so just tell me the color code and thats it
  2. Hey guys i bought a new engine and loom after mine was sold out, i then realized that the blue was shattered and just the wires were left. Can someone help me please with this. There is 7 on that plug but i dont know which pin to put it in. Both sides are color coded so just tell me the color code and thats it
  3. need help wiring emanage blue on ecu. found info only for ep82
  4. can anyone help with base map??
  5. Because that the arent any good tuners in my country i need help mapping an emanage blue ecu on a fairly standard 4efte. Can anyone give me details on what i should to obtain optimum power gains any help would be greatly appreciated.
  6. Saw some adjustable are they any if I had one fit and adjusted?
  7. U should check the plugs mate. I think there's 2 plug on my ep91
  8. I'm in need of a forged 4efte engine with ecu also, can take complete car if the price is ok.
  9. I have a 4efte and need to change crank I have a 2e non turbo crankshaft. Can this work without worries on my engine? Also the crankshaft con rod journals are hollow on the 2e crankshaft whereas the 4e ones are solid would this be a problem also?
  10. i heard persons running 5efe oil pumps on 4efte but im not sure if this can work but can it ? i need an oil pump for my 4efte but 5e ones are significantly lower so can it work
  11. Hey guys I found out when I turn my ac on my rpm fluctuates from idle to about 1500rpm continuously until it stalls. I need urgent help to solve this pls
  12. ok. thanks mate will do it and let u know.
  13. can someone point me in the right direction im a student and i can't really afford a rebuild that much
  14. Plugs were a bit black not too black thou . Also theres not much smoke coming from exhaust
