Callum-Glanza
    16
    Highland
Callum-Glanza's Achievements
  1. Spot on👍
  2. If this was loose would it cause a leak? Thanks for the quick replies!
  3. Recently the oil light keeps flickering, only when I go over bumps though, dipstick is full, any ideas? Cheers!
  4. Just done a gearbox change on my 4e-fte and there was a knock that felt like under neath the car. Since then I don't know if it's a coinsidence or not, but since then the eml came on, I then turned off the car, back on and it disappeared. Since, it comes on after about 10 minutes, haven't had long to look at it, not sure if it's coming on once it's up to temperature. Just wondering if there is anything to look for? Thanks
  5. As title states, I've been advised that 0w-40 oil is to 'thick' and been pushed to buy something like 5w-30, what's the best option. I've been using fully synth 0-40, just wondering what's best as there is mixed opinions.
  6. No longer need bracket Please lock
  7. Its the rear engine mount, coming off the back of the gearbox, there's three bolts. Trying to upload a picture of where it is on the box. Its not an lsd box either, the bush had gone in the previous mount and snapped a head off the bolt and ripped one of the bolts right out of the thread, along with this - cracking the bracket
  8. In need of the bracket from the box to the rear engine mount, tried lots of places, someone please help!
  9. After fitting the new engine, i had noticed previous owners make to brackets had rusted and were no longer useable. I can't find anywhere or any topics relating to this, looking for what metal that can be used and fabricate some myself or is there somewhere they can be bought?£££
  10. Anyone that could point me in the right direction of a gear box for my 4e-fte would be really appreciated!
  11. Found the problem! A vacuum pipe from the sensor to the intake has fallen out the housing, back running good now!
  12. Not sure is this helps but lugging, like a strong jolting happens in the lower revs, not sure if that's down to me or not just happens when taking off? But if I feather the throttle it goes away, dunno if it's because I'm actually going through the revs or if this a problem?
  13. It wasn't doing this before the engine change so hopefully it's just a loose connection somewhere. Sorry but what is 'TPS'? Thanks haha. No driving about till it's done!✔️
  14. I'll get back on Friday night. Suppose what I'm trying to say is, is it okay to drive the car with the fault? Have no confidence in the car, but I need to run it :\ don't want to cause further problems. Will I benefit from a rr session?
  15. I was informed that an original ecu was put back in place of a flashed ecu, but I don't know if that's true or not. I'all get on to that asap, currently running a ct9 hybrid, with 0.8 boost, been told to set the actuator higher, closer to 1.2 Thanks for the reply!
