EpStar
    4
    Here
EpStar's Achievements
  1. Thanks for the link, Ya from a levin, is it the outer cv joint your looking for? Nearly sure I seen a listing for a new one on some site in the last few weeks, just cant remember where
  2. This is good info, I have trawled through several forums and nobody talks details. Thats interesting about the balljoints and lower arms, there might be something there alright. I'll do some digging on that see if I can find something before commiting to a custom shaft. Shortest shaft I found to date is from an Ae111.
  3. Thanks for reply, thats very helpful I looked at cutting cambelt side but it looks like there wouldnt be chassis leg left after to clear everything, would need major strengthening too. Option 2 sounds good, when you say custom did you have one made up? I looked at bearing/stub axle combinations and couldnt find one to work out on paper, is there a straight swap or does hub need machining? Also have been thinking would there be a slightly longer lower arm to suit ep82 chassis giving a little bit more room to get a oem shaft combo to work out
  4. Hi, Im new to on this forum. Not sure if this the correect section to post this? I'm in the middle of doing a 20v conversion on a ep82, I need advise on driveshafts. I have the engine hanging in the engine bay, I have tried several different toyota shafts with no luck yet of matching two to suit lengths needed. Anybody done this and know what combination of shafts work? Making custom mounts isnt a problem. Thanks
