macoiae92
    4
    Saudi Arabia
macoiae92's Achievements
  1. right at it, Sir! thanks Cheers!
  2. took your advice, sir! got an HKS adjustable actuator, and a boost gauge for that Will be taking it to a tuner to do the proper installation also, i am planning on an FMIC + td04 upgrade. i hope to add some HP since the ae92 body is heavier than the starlet cheers!
  3. noob question here i read from one topic that to manually adjust boost, its either you lengthen or shorten the actuator rod length. longer = less boost / shorter = more boost. i dont have a electronic boost controller. how far can i safely shorten the rod on a stock ct9b turbo? what else need to be adjusted to accommodate the extra boost? i run a stock 1st gen 4E-FTE engine on c56 LSD transmission on an AE92 corolla. thanks
  4. hi i am kris from riyadh, saudi arabia i have an ae92 corolla back in the philippines fitted with a 1st gen 4EFTE all stock engine. looking for advice on how to properly add HP to the engine.
