Vinpetrol
    5
    Highlands
Vinpetrol's Achievements
  1. Cheers Tim I put a request in the wanted section for used springs and hubs etc to source the parts I haven't replaced yet and I mentioned why I needed them and I got a reply from the moderator Morgey who suggested it might be out of line because I should of jacked up the wheel before tightening the suspension bolts up and I definitely didn't do this so I need to jack it up and get this done first . Do you think if it is out of alignment because I didn't put it together properly could effect the spring and cause the spring noise? This is great help , thanks guys. Vin
  2. Thanks Daniel How can I check the strut top mount? Can I check it without removing it ? The spring looks ok . Cheers Vin
  3. Hi Morgey Thanks for replying. So if I didn't do this would this explain why it's leaning out? What would I need to do to put it right? Cheers Vin
  4. Hi All Car has had a knock on front corner ( slid into kerb! ) Replaced wishbone, drop link , lower ball joint and discs ( from Id worxs) but something's not right as the car won't line up and the wheel leans out at the top. It's got coilovers and there's a clanging sound coming from the spring when you lock the steering . Any ideas? I'm thinking about changing hub and putting it back to standard springs to see if that straightens it up Any help much appreciated Vin
  5. Hi I need a pair of front hubs , wishbones and standard springs for an ep91 Mines had a minor front corner impact on one corner and I've fitted a new wishbone, lower ball joint, drop link and discs but for some reason the wheel is leaning out . I don't know what's making it out of line so if I put it back to standard and see if it lines up! Cheers Vin
