Hi I've got a 95 ep82 and im replacing my head gasket. I see the new head bolts I've got are 2 different lengths.. and I didn't even think to look at the length of the ones I pulled out, so I don't know where the longer ones go? Do the longer ones go in the front (exhaust side) or rear?
Also, can someone help with torque specs on head bolts + cam bearings (most important), nd manifolds, etc? I've seen a few here link toyotagtturbo.com, but that website must be under construction or something? Can't seem to get it to load properly.
Also, Im sure I've got an oil leak from my turbo because I've got oil through my intercooler.When I took the turbo off, I saw all there was was a thin metal flange gasket between turbo and hose that goes into sump. Visually it looked OK, is there supposed to be an O ring or something else? Or can it leak internally? If it leaks internally, I'll just chuck it back in.
Is there a blow up of all the hoses, that come off the intake manifold to show what hoses go where? That'll solve my nightmare for when I put it back together, I didn't put much thought to them before I took them off..
Thanks
