A17 HYT Glanza V
    8
    Skipton
A17 HYT Glanza V's Achievements
  1. Not just sits there dead as a fart and il get that ordered first thing in the morning, cheers pal
  2. Thanks for all your help
  3. result guys! Up and running engine management lights off too... mot this week end and spray and temp needle just left now
  4. Yeah I've ordered new plug and wiring as old one nakered and none repairable once Parts fitted will find out if we have lift off
  5. 22 water temperature sensor no signal at THW Water temperature sensor ECU 52# knock sensor No KNK1 signal to ecu Knock sensor loose Malfunctioning knock sensor just got the same Just gona check them both now cheers il update soon of results #fingers crossed
  6. Cheers patches just done it now shows code 22 and 52 from what I can make of it 2 flashes then pause then 2 flashes pause then goes 5 flashes and pause and 2 flashes and repeats itself any clues on code I'm going to search them now
  7. Thanks for reply gazzza g Hmm come to think about it mate the temp needle doesn't work aswell and yeah it's showing a engine man light but found the diagnosis plug under hood but I don't have the connector. On idle it have a little miss and still smoking but I reckon that's due to not been run for so long too just been parked up need to get on road asap
  8. Hi all, I'm new to the game!! recently bought a glanza needed a new head So done that at the same time replaced timing belt water pump too and all gaskets the car now struggles to start alone but once running you can switch it off and back on fine but if left over night will not start think it's the fuel pump ?? Or I may be wrong.. is there anything out I should look for before changing the fuel pump thanks guys looking forward to your replies
