RenBlue
    6
    Europe
RenBlue's Achievements
  1. I tried a few different things to no avail. I notice a small oil sweep/leak where the cylinder head and block meet. I thought maybe the headgasket was fitted upside that was causing the problems. I got someone to fit one for me 2 weeks ago so I stripped it down today. Is this the right way it goes? It only seems to fit one way ?
  2. Its a carburetor engine. I disconnected the exhaust at the manifold, the problem still occured. I checked the timing,everything seems fine. I thought then maybe it was an over fuelling problem?
  3. Hello, having an issue with my toyota starlet 2e engine. When I start the car the exhaust manifold gets hot almost straight away and proceeds to get hotter. Has anyone seen this issue ? Thinking the exhaust is blocked or a timing issue ? I would appreciate any help
  4. It is a carburetor engine
  5. Hello, having an issue with starting my car. I have an 1986 Starlet 1.3 as a project. I fitted the engine everything is wired and plumbed up. When I turn the key nothings happens. I fitted a new battery, checked all fuses, check all the power and theres power going to everything as it should like the starter,alternator,ignition etc. Connected the starter to a battery and it spins up no problem. Would it be an earth problem? Would anyone have an idea of what else it could be ? Appreciate any feedback!
  6. Greetings folks, recently bought an 1986 Toyota Starlet. Here for some help and advice. Cheers!
