chanhonam
    8
    radlett
chanhonam's Achievements
  1. Checked out my plugs today, appear to be oily and darkish brown. Throttle cable appears to be a tad slack too. Dizzy, leads and vaccum lines appear to be fine though.
  2. It's an N/A SR with the usual Corolla inlet manifold mod. No long drives either since work is pretty near.
  3. morgey - getting about 240 odd miles for 3/4 tank full. Luke & ryan - will check those on weds/thurs.
  4. Had that changed about 4 months ago and still having the problem. Been searching around but doesn't seem a very common problem amongst Starlets so it's got me stumped although on othe makes MAF/MAP sensors have popped up, so could it be that?
  5. Hi guys, Been having a problem off and on for a while now where the car seems to heistate while accelerating. I put my foot down and there is a delay of a second or two before it goes. Clutch and gearbox seem to be fine no crunching or the like. Any ideas what the problem may be?
  6. Thanks for the reply mate Will definitely need to get this sorted before MOT next month. asad 5dr is the man to talk to then?
  7. Hi all, Would like to ask you guys whether the rear shocks on a Starlet SR are the same as on the other Starlet models. Reason is, my SR has developed a creaky/knocking sound from the right rear. In addition to this when going over certain bumps in the road (normal road driving speeds) it will make the rear twitch/wobble a bit.
  8. Thanksfor the info Now to actually get a set
  9. Are these still available and would I need new electrics etc to connect them up or could I use the existing parts?
